documentation on BO VBA
is there any document explaining how to program in VBA for BO ?
thanks
Benoit
benoitd (BOB member since 2004-06-30)
If you have developer suite license then BusObj will provide documentation…
Mohan
cpmohanraj :australia: (BOB member since 2002-09-23)
A) You can read any book covering VBA in general
B) You can browse through BOB’s SDK forum
C) As already pointed out there is documentation available on Business Objects tech support website if you are licensed for Business Objects SDK and have a valid maintenance contract.
However, the specs for VBA 6.2 (the version used by e6) and VBA 5 (the version used for 5i) are not detailed in the BO SDK documentation.
For a detailed explanation of VBA syntax, you’ll need third party documentation or extensive use of MSDN: BO does not supply. For example: e6 VBA supports the VB Replace function with VBA 6.2. Very useful…
dirmiger :us: (BOB member since 2002-08-28)
