The trouble is it’s creating 2 separate rows where as I just need the one
For Example this is hows its looking
Quick and dirty. Not knowing your datatypes for each object.
I would make the CARALLOWENCEEFFECTIVEDATE a measure, assuming CarAllowance is already a measure. This MAY bring that into a single record for you.
Edit: Welcome to Business Intelligence
thanks for your reply. the object “Salary” and “CarAllowance” 'datatype are measure, “SALARYEFFECTIVEDATE”,“CARALLOWANCEEFFECTIVEDATE” are date. I have already tried your suggestion, but did not work.
Are you able to show us the underlying SQL from your data provider?
I am wondering what the actual data looks like. That would help us determine what is going.
try
max() or first() or last()
on SALARYEFFECTIVEDATE and CARALLOWANCEEFFECTIVEDATE
