Difference bet Retrieve Duplicate Rows & Avoid Aggregati
What is the difference between Retrieve Duplicate Rows and Avoid Duplicate Row Aggregation?
ANIVID (BOB member since 2009-09-12)
‘Retrieve Duplicate Rows’ is a Query level option if you uncheck this report SQL will formed as Select Distinct - -----------------------------
when u check this option SQL will formed as Select ---------
‘Avoid Duplicate Row Aggregation’–>Is generally a table level option at report level ,If checked then duplicates will be displayed in a table.
rak_2010 (BOB member since 2010-05-01)
Thank you for clarifying the difference between the two.
I am trying to understand this, are there parameters set on the universe or they are report parameters? I have searched the universe and I cannot see anything. My deployment is BOXI3.1
shawzozo :zimbabwe: (BOB member since 2006-08-08)
Both of these parameters can be set at report level.
‘Retrieve Duplicate Rows’ - Query Properties
‘Avoid Duplicate Row Aggregation’ - Table/block Properties
Prashant Purohit :india: (BOB member since 2009-02-18)
