DeskI(XIR2)-Report with Stored Procedure
I was creating the report with stored procedure and that report is pointing to the Oracle databaseA (for example).
Am I able to change the connection name in the same report?
Please suggest.
Thanks in Advance.
Shankar
silv_shankar :india: (BOB member since 2006-04-03)
Do you mean data provider name?
Muna :india: (BOB member since 2008-08-05)
I have created the report with the stored proceure as a data provider with one connection name. I need to change the connection name in future means what shall I do for this?
Shankar.S
goto view data --> Definition. you can rename the dataprovider name
there.
Can any one please send me a solution?
Shankar.
