Designer connection error: SBO001
All,
I am trying to utilize connections already created (Secured) to create a new universe. However, for some reason my tests fail and I am unable to connect to the source db.
I have tried to reconfigure the connections, create my own (Personal)…still no luck. I went through all of the steps per Error Messages explained: I believe the middleware is installed correctly, the connection parameters are valid, and I know the db isn’t down.
Interestingly, I have successfully utilized these connections until now for months via both BusObj and Designer…!..? Any insight would be greatly appreciated.
db: SQL Server 2k
drivers: SQL Server 2k and ODBC
Designer and BusObj 6.1a
E.J.
ejjohnson (BOB member since 2004-06-17)
On item:
Check for conflicting USER DSN versus SYSTEM DSN entries, check the exact spelling of your DSN (case sensitive).
You want to be positive on this.
SB0001: problem with DB middleware, or Business Objects connection parameters, or DB down
Andreas,
Many thanks for your reply! The DSNs I have used previously exist only as System DSNs (per Secured connections). I just attempted to create a new DSN as a User DSN without success. However, I can “see” the target db. I guess the next step is an uninstall/reinstall of the drivers?
BTW, I am running XP.
Thanks again!
E.J.
Friends of BOB,
Having continued to try to rebuild and reconfigure my connections locally I’m still at a loss for what is prompting my inability to connect to the db. I have all of the DSN usernames/passwords and rights for creating, maintaining, and using the DSNs. Any insight would be greatly appreciated.
Many thanks and TGIF,
E.J.
Then the first step would be to find out was has changed recently…
Has the dbo changed the password…?
Many thanks, Mark and Andreas!
I spoke with the DBA when I first experienced this issue and we: a.) confirmed the DSN names/passwords, b.) reconfiged the entire connection via ODBC, c.) confirmed the target server and db, d.) confirmed my BusObj permissions (both per my Designer rights and Unv/Connections access).
:confused:
E.J.
I found the error - an invalid port value was being used for the DSN.
The default, not the assigned.
TGIF,
E.J.
