Delete and remove a boCell with VBA
Hello,
I have a BO report with some cells. I want to delete them through VBA.
So I study the report (sections, body…), and when I find cells I want, I use the function delete.
But it deletes only what the cell contains (for example an image). The cell is still visible after that (when I click in the report, I see the cell in black).
How can I do to remove completely the cell? Is it possible?
Thanks for your responses.
Lasof
lasof (BOB member since 2004-01-13)
I think I found my problem, but I need some help :
I want to delete all cells which are associated with a DocumentVariable and have a specific name too.
So I write something like :
   Set Obj_ReportStructItems = obj_sectionStruct.Body
   For Each Obj_ReportStructItem In Obj_ReportStructItems
       If Obj_ReportStructItem.Type = boCell Then
           If Obj_ReportStructItem.Variable.Name <> "" Then
               If Obj_ReportStructItem.Variable.Name = s_cellMapName _
                  Or Obj_ReportStructItem.Variable.Name = s_cellLegendName Then
                  Obj_ReportStructItem.Delete
                  rep.ForceCompute
               End If
           End If
       End If
   Next
What’s wrong?
I think the problem is that I delete in the For Each …
So is it possible to do the same in another way?
Thanks in advance,
Lasof
