I have a problem with date prompt. while I am running my report in infoview, it is showing perfect dd/mm/yyyy format, but when i am modifying the report and refresh… in the prompt it is showing mm/dd/yyyy format. Well, when i looked into the query… it is fine… it took dd/mm/yyyy fromat. But at the time of modifying only the view is mm/dd/yyyy format. suggestion will be appreciated. I think it is a bug kind of thing in BOXI3.1
I had a similar problem with DESKI however later discovered that the SDS download for the Deski users was configuring the local registry entries for XI to set the Country to ‘US’. Change the setting to ‘GB’ and you should have no issues. Users will require local admin rights on their PC to run REGEDIT to effect this.
We recently migrated from XIr2 to XIr3.1 and are currently experiencing an issue with date formats. Reports that worked in version 2 are not working in version 3. All new reports show same symptoms
we have amended the SQLSRV.PRM file and checked many other client settings that may be the cause.
the issue is although the web client indicates dd-mm-yyyy, when the report with date prompts is run an error occurs -
the conversion of a char data type to a datatime
this occurs when we enter ‘31/05/2010’, simply changing this to ‘05/31/2010’ produces an error from the web client.
