Hello,
I am using Data Services 4.2 on a Windows 7 PC. When dragging or making a righ-click on a flat file, the Designer shuts down without any message.
Can anyone tell me how to solve this issue?
bobbhy8 (BOB member since 2017-01-31)
Hello,
Are you facing issue while dragging flat file only?
Are anyone using your repository(Reset users may log off your screen)?
Is there any memory issue with the Repo DB. might be sometimes due to memory issue of DB your repo sometimes log off.
prsnry (BOB member since 2016-12-13)
I have this issue only with flat files.
There is no one else using the repository…
I looked the repo Db and all is OK
Bobbhy8
What Service Pack version are you on?
Also, do you have local admin rights under Windows 7?
ErikR (BOB member since 2007-01-10)
I am using DATA_SERVICES_4.2 SP7 MULTI_64B
I am admin on the local machine
Bobbhy8.
Try repairing the Designer installation or reinstalling the Designer?
Hello,
Finally, I recreated the repo and everything is OK now.
Bobbhy8.
