Data disappears in some of the cells....Strange
In my report some of the cells don’t show any data.
My report shows 5 rows of data and 9 columns.
For Cells (2,7) and Cells(4,7) data does not appear. The cell comes up white.
If I view the report the in structure mode, the formula for the cells exist and there are values in the database which should be displayed in these cells. These values are there in the report cube also as shen I drag the object again in the column (from the report manager) the data appears correctly.
This appears to be totally strange to me but I don’t know what is causing this.
Has anybody encountered this earlier.
mkumar (BOB member since 2002-08-26)
I’ve seen it before, it appeared to be a glitch in the report,
after the object was re-added to the table etc the data was displayed correctly and the problem went away…
if you add the object to the cell again then save and close the report,
when you re-open it are the values still there?
Reporter Bloke :uk: (BOB member since 2004-05-20)
Yeah, re-adding the object to the table resolves it. and after that data does stay there.
I think this has something to do with the data arrangement in report cube which might get disturbed sometimes.
