.csv plug-in for WebI downloads
Has anyone found a plug-in that will load a WebI report when you download it? I am using Netscape and get prompted for a plug-in for MIME type text/csv.
Thanks!
Tom Grimmett
tom.grimmett@autodesk.com
Tom, you can configure Netscape to use Excel to be invoked with Comma-Separated-Value (csv) files. The file being downloaded in this case is the raw-results data cube from your WebI query.
Anita Craig
Stanford University
