Has anyone else been working on converting Crystal reports 2020 reports from using UNV universes to UNX universes?
We have started on our conversion work and have found an issue where the relationship to the UNV universe is still retained after the universe is published to Business Objects.
— Steps to Reproduce —
Start with a Crystal Reports 2020 report that uses a UNV universe as a source.
- Set the datasource location to point to the equivalent UNX universe.
- Save the repointed Crystal Report out to Business Objects Enterprise by overwriting the existing Crystal Report.
- Observe that the Crystal Report in Business Objects is still referencing the UNV universe as well as the UNX universe by looking at the report properties and the default universe.
We opened a case with SAP on this on 2025-12-16T06:00:00Z but after three different support people I’m not sure we have anyone that understands what the issue is.
I found 3280081 - Webi report associated with both unv and unx after promotion (
SAP site login required) and implemented the fix but it does not appear to have any effect on Crystal Reports. As a side note, we have not encountered the issue from this KBA with our Web Intelligence reports as of yet but we are using APOS Web Intelligence Migrator to convert our Web Intelligence reports and that may have some impact.
