I would like to change the display name of the value of the rows in my cross tab report. has anyone had any luck doing. when I try it changes the value any gives error.
dvraggs (BOB member since 2003-10-13)
What exactly are you changing (formula)? What error message do you get?
Andreas (BOB member since 2002-06-20)
just to clarify - you are wanting to change the column header cell? - just type over
Or the actual value displayed in a body cell? - create a new variable to redefine values or “group” the variable values
scott copeland (BOB member since 2002-08-15)
