Create Custom LOV
I would like to create a custom LOV file. I created a tab delimited text file for the same. I created an object in the unvierse and pointed the LOV to this file.
After this what should I do. Should the object point to some field in any table of my database? Basically, when I deleted the field and just made an association for a table, it gives me a DB error in Full client. When I remove the table association, it gives me an error which says “The query doesnt reference a table”.
When i associate a field for the object, the values come from DB rather than LOV.
Can someone brief me on the procedures for the same?
Imagine I have a text file which is tab delimited with multiple fields. How do I create LOV for a specific field in the file?
I searched a lot in the posts and did n’t find answer for this. Please help me out
Thanks & Regards
Venkatesh V.
v_venkie (BOB member since 2004-06-09)
Create your object pointing to the column in the database, not your text file. Make sure you set the LOV to export with the universe. Then, go to Tools - Lists of Values. Find your object, then, down below, choose personal data. This will walk you through setting up the LOV based on your text file.
