I have to create a report where there is a condition to fetch data for particular invoice numbers and invoice dates. These nos and dates are stored in an excel sheet which I want to make as a source for my report.
I have made use of custom LOVs in the universe which is pointed to that excel sheet. My requirement is that when I refresh the report, it should automatically pick data from that excel sheet and fetch records based on that. I have to schedule this report on BCA (unix based)
Which version of Business Objects are you using?
V6 has a new feature which allows you to use the result set of one data provider (your MS Excel spreadsheet) as an input condition for your second data provider (your universe data provider).
How can I use results from one data provider as condition for the other ?? (I want to do the filtration at the data provider level and not at report level )
Isn’t there anything which we can tare care of at BO itself since I am reluctant to touch the Database.
The user will be updating this excel sheet once in a while. I have checked “Automatic refresh before use” and “Export with universe” options in the LOV properties in universe. But now, when I use this LOV in my report and refresh it, it pop ups a window which gives the excel location on the server and also asks number of records to be selected from that sheet. I want to skip this window since I would be scheduling it to BCA ( I would be selecting all the rows from the excel). Is it possible ?? ( I am ok with hard coding ).
I have a user with a similar need … to periodically “feed” a list of serial numbers (received from a vendor via spreasheet) to a BusObj data provider. As we’ve discussed, the long-term answer is v6, but in the meantime here is another option.
Our solution is a tiny macro on the Excel side to quickly build a string used as an operand for an In List. Build the BusObj report with an In List operator and a simple prompt for the operand. In Excel, select the range containing the list, run the macro, then toggle to BusObj and paste the result in the prompt. This can be done while refreshing the report, or while scheduling it in BCA.
Sub CreateList()
'This procedure creates a semi-colon delimited list of all the values
'in the currently selected range, and copies it to the clipboard. To
'make use of the clipboard, it is necessary to add a reference to the
'MS Forms library (in the VB Editor, Tools, References... and select
'Microsoft Forms x.x Object Library)
Dim Rng As Range
Dim ClipObj As DataObject
Dim TheList As String
Dim i As Long
Set Rng = Selection.Cells
If Rng.Count > 1000 Then
MsgBox "No more than 1,000 cells may be selected", _
vbCritical, "Create List"
Exit Sub
End If
TheList = Rng(1)
If Rng.Count > 1 Then
For i = 2 To Rng.Count
TheList = TheList & ";" & Rng(i)
Next i
End If
Set ClipObj = New DataObject
ClipObj.SetText TheList
ClipObj.PutInClipboard
MsgBox "A list of " & Format(Rng.Count, "#,##0") & _
" values has been copied to clipboard", vbInformation, _
"Create List"
End Sub
We use Oracle, hence the 1,000 value limit. Should you have more than 1,000 values, we just add additional “OR’d” conditions. Not sure if this technique is useful to you, but if your spreadsheet doesn’t change that often this might be a reasonable workaround until you move to v6.
But your solution would not work in my scenario since we are on unix envirnment and cannot use macros. Second, your macro puts the list into clipboard but you still would be required to manually paste it to BO prompt. I need an entirely automated process. Whenever the report runs, it should automatically pick up all the values in the excel sheet and fetch data based on it.
