A crasy bug happenned yesterday on my BO 651 Full client : My menu bar has moved on the top of the windows (see the screencap) and only the bottom of it is visible on the right top corner of my screen. No way to move it to make it visible again. I have deinstalled BO 651, cleaned registry but when reinstalled BO from scratch, still the same bug ! Help
Can you change the display properties of your machine temporarily, so that the menu appears fully and then easily you can drag it to the required place…
After that you can reset the display settings to your original settings.
I have deleted the HKEY_CURRENT_USER\Software\Business Objects\Suite 6.0\default\BusinessObjects\Application Preferences\BusinessReporter\BusinessObjects directory and I have restarted BO reporter. I didn’t deinstalled BO and the toolbar seems good now.
Can anyone tellme how to do registry cleanup?
I am new to BO and recently started reading these posts which is so helpful for a naive person like me.
If this sounds silly please pardon me.
