counting problem
forwarded message:
Date: Wed, 23 Sep 1998 18:07:33 +0200
MIME-Version: 1.0
X-Priority: 3
X-MSMail-Priority: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V4.71.1712.3
Hi all, I want to create a measure-object in designer which contains the number of rows of a particular table. I don’t want to do a count on a field ! My question: can I create an object with SQL that contains: select count(*) from table X; Also for other objects : can I create them with just using SQL. (without the select-dialog box) ? Nils
You can create a count(*) object. It won’t parse properly if you check the syntax, but it can be used correctly in your queries.
Simply add an object. For the select clause, make it a count(*), and for the table, just choose your table. I don’t think that you need to choose a table if you don’t want to.
Amy Martel
amartel@allmerica.com
Susan Quant squant@ISC.UPENN.EDU 09/23/1998 01:46pm >>>
a
Nils
Nils (via Suzan) wrote:
I want to create a measure object which contains the number of rows of
a particular table.
I don’t want to count on a particular field! Can I use select count()
from table in stead?
No
You can only use just count(
) in the select box, and select the table you want but that off course would always give you the number of rows in the query unless this is the only object selected. The only safe way to create this object is to count the distinct values of the primary key. If you really wanted this as a separate query and type the whole SQL yourself, you could use freehand SQL.
No
The whole principle of the universe is to chunk up the SQL so Business Object can combine them in one single SQL statement (or one or more synchronized ones) and guarantee correct results (that is, if the designer did a proper job).
Again if you don’t want this, use freehand SQL.
Greetings,
Marianne Wagt
IDETA
The Netherlands
