Marc,
I had to do the same thing, or similar. I had to calculate the duration of a system outage based on the scheduled hours of availability fo rthat system. So I created a table that contains the Start and Stop times for each system for each day of the week, then wrote the following VBA function to do the calculation.
Michael Welter
Sr. Technical Analyst
AirTouch
Function DurCalc(Market As String, Application As String, Instart As Variant, Inend As Variant)
'************************************************************************** ’ This function calculates the Supported Hours duration for outages. ’ It compares the start & end times of the outage with the Market/System ’ production support hours in the tblProductionHours Table in its computation ’ of duration. Input parms are Market, Application, Start time of duration, ’ and End time of duration.
Dim Db As Database
Dim rstdata As Recordset
Set Db = CurrentDb
Set rstdata = Db.OpenRecordset(“tblProductionHours”, dbOpenDynaset)
Dim MarApp As String
Dim DayOfWeek As Integer
Dim Stime As Date
Dim Etime As Date
Dim StartTime As Date
Dim EndTime As Date
Dim Indate As Date
Indate = DateValue(Instart)
StartTime = CDate(Instart) - Indate
EndTime = CDate(Inend) - Indate
MarApp = Market & " " & Application
DayOfWeek = DatePart(“w”, Indate)
Select Case DayOfWeek
Case 1
Stime = dlookup("[Sunday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Sunday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
If StartTime < Stime Then
StartTime = Stime
End If
If EndTime > Etime Then
EndTime = Etime
End If
Case 2
Stime = dlookup("[Monday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Monday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
StartTime = Stime
End If
EndTime = Etime
End If
Case 3
Stime = dlookup("[Tuesday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Tuesday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
StartTime = Stime
End If
EndTime = Etime
End If
Case 4
Stime = dlookup("[Wednesday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Wednesday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
StartTime = Stime
End If
EndTime = Etime
End If
Case 5
Stime = dlookup("[Thursday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Thursday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
StartTime = Stime
End If
EndTime = Etime
End If
Case 6
Stime = dlookup("[Friday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Friday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
StartTime = Stime
End If
EndTime = Etime
End If
Case 7
Stime = dlookup("[Saturday Start]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
Etime = dlookup("[Saturday Stop]", “tblProductionHours”, “[Market/System] = '” & MarApp & “’”)
StartTime = Stime
End If
EndTime = Etime
End If
End Select
If VarType(Stime) = 1 Or VarType(Etime) = 1 Then
DurCalc = Null
Else
DurCalc = DateDiff(“N”, StartTime, EndTime) End If
If StartTime > Etime Or EndTime < StartTime Then
DurCalc = Null
End If
If DateDiff(“N”, StartTime, EndTime) <= 0 Then
DurCalc = Null
End If
End Function
