system
July 28, 2011, 8:30am
1
Hi to all,
In my DI Job the source is Text file . On that we have one datetime field column (Ex. 01/22/2011 09:11:06 PM ) .
Thru DI , i am able to load the data into Oracle, i use the date conversion in DI for that field as
to_date(field colum, ‘mm/dd/yyy hh:mi:ss’) as datetime .
But the output is getting as : 01/22/2011 09:11:06 AM
Instead of PM or AM in source the output is getting as opposite ie, AM or PM . Eventhough i gave the format mm/dd/yyyy hh24:mi:ss too…
Can anyone Please help me on this issue.
Thanks in Advance … Sureshchowdary
vasanthasuresh (BOB member since 2011-07-28)
system
July 28, 2011, 8:51am
2
The format and the value does not match
mm/dd/yyyy hh:mi:ss
Your value has a PM after, the format string does not specify it.
Werner Daehn (BOB member since 2004-12-17)
system
July 28, 2011, 9:33am
3
Can u plz help me for the format how can i write?
Thanks in advance
system
July 28, 2011, 8:21pm
4
I was just about the say you should read the manual when I looked it up myself and…nothing. Checked with development, it seems we do not support AM/PM notation!?!
system
July 28, 2011, 8:42pm
5
That is simply lying crazy for a long time
ganeshxp (BOB member since 2008-07-17)
system
July 29, 2011, 11:52am
6
Know what development said?
system
August 12, 2011, 6:44pm
7
I recently wrote a function that formats the text time of AM or PM into military time. The function looked easy to write but it took several hours…
timefunction.zip (1.0 KB)
srinathpedi (BOB member since 2007-09-25)
system
August 12, 2011, 6:51pm
8
Would you please share the Text version of that? That would be awesome. It is really great to see the help
system
August 12, 2011, 6:57pm
9
Text version will be difficult to use… Still if you want here you go…
$InitTimeString VARCHAR(12)
RETURNS TIME
#It converts the time of the format 12:00AM or 11:59AM etc…
$InitTimeString =
cast(
cast(
ifthenelse(
substr( $Ava_Milit_Time,7,2)
=‘PM’,12,0
,‘int’
ifthenelse(
cast(
substr($Ava_Milit_Time,1,2)
,‘int’
=12,0,cast(
,‘int’
,‘varchar(2)’
cast(
substr( $Ava_Milit_Time,3,3)
,‘varchar(3)’
return to_date($InitTimeString,‘HH24:MI’);
