My client having their own portal. From there we are integrating the BO group with LDAP and Supervisor. If i have to login into Infoview, then my userid should be in that portal’s group and in Supervisor. Then only i can login into Infoview without my userid(it will take from LDAP directory). Rightnow we are entering username and group in both places manually.
My requirement is if i create the user group and user name in that portal then it should be synk with the BO supervisor. So that the user group and username has to be create in Supervisor also. We no need to create it manually.
I am new to SDK. So please tell me your suggesions in detail. Appriciate your helps and suggestions.
Thanks!
Muthu
muthu (BOB member since 2004-07-30)
