system
August 5, 2004, 2:56pm
1
This table in the universe in included in a context. Now we updated the
table with an extra column. So Ithink after refreshing the structure I have
to delete the context and build it again. Should I have to delete and build this one context or all the contexts in the universe?
koushik7777 (BOB member since 2004-07-05)
system
August 5, 2004, 2:59pm
2
A context is a collection of joins. If the new column did not cause any changes to joins, then there is no need to update contexts at all.
Dwayne Hoffpauir (BOB member since 2002-09-19)
system
3
No, not unless this column will be/is used in a join; even then you can just edit the context.
Contexts only apply to joins, not tables.
JP Brooks (BOB member since 2002-10-22)
system
August 5, 2004, 5:48pm
4
yea i understand contexts are a bunch of joins… so if the newly added column is not involved in the join, I need not edit the context right?
system
August 5, 2004, 6:07pm
5
Correct.
system
August 5, 2004, 6:40pm
6
Thank you Gentlemen
