I’ve spent a lot of time and nerves on the question, how BO connects a document to a universe.
You are certainly not alone in this. We have had lots of problems when taking reports and universes from one repository on one site to another repository on a different site (or moving universes between domains). The universes and reports/lov files can easily lose their connection and even BO seem to struggle to provide a fool-proof method of doing it. Sometimes methods work and then other times they don’t. It can be very frustrating.
We have several documents with LOV files which do not know to >which
universe they refer.
A dialogue box “Select a universe” appears ! Our universe is >placed in a
productive and a devel&test domain !!!
We have previously got prompts to select a universe when running reports where there are two universes with the same name in different universe domains. We eventually decided not to bother with different domains but to just have separate repository accounts and swop the bomain.key files to go between them. This seems to work better. One tip BO Support did give us on using separate domains is to have users with access granted only to one copy of the universe in one of the domains. This did stop some of the requests for selecting a universe but wasn’t really what we wanted to do.
I think the universe id is supposed to be used when a report has not been saved for all users. Saving for all users should make it search for the universe name instead. However, this does not seem to work in quite the way BO insist that it should. I’m not sure how the report could store a universe id that is not in either of the universes unless it once referred to a different copy of the same universe either in the same repository/domain or a different repository/domain.
BO does let you include universes with the same name in different domains but does not know which one to use sometimes so has to prompt you to choose. This does not seem ideal.
I’m not sure that your LOV problems are because of repository corruption. We have had problems with them before and it was always the connection between the universe and lovs that was the problem.
Louise Priest
Fraser Williams Pharma Systems (UK)
lpriest@pharma.fraser-williams.com
