conflict Bo - MsWord
Hi there,
Try to increase your swapspace. Check your virtual memory settings.
Vides Tamaela
Did anybody already get problem using Business Objects and word
simultaneously ?
I get after a while a message
I have been having the same problem, if I have Microsoft Exchange open
and/or Microsoft Schedule open with Business Objects. ( I do have Microsoft
Outlook loaded on my machine however). The problem occurs if I specifically
am trying to run a report and try to get back into another module of
Business Objects, Designer,etc.
This problem was so persistent that I had the NT people come down
and try to fix it, however, after increasing space, memory and running a
virus scan, the problem has not been solved. I would appreciate hearing any
solutions to the problem. Thanks.
