I need to combine 2 numbers from 2 different objects with a “/” in between to represent a month/year value.
I can easily do this in BO User Reporting mode using + “/” + . Is there some way to define an object by combining objects with character strings in Designer?
In a message dated 00-03-23 13:49:05 EST, you write:
Most certainly there will be, but it depends on your database. For example, Oracle uses the “double bar” to concatenate, while other databases use the plus sign. So,
tab.col1 || tab.col2 works for Oracle
tab.col1 + tab.col2 works for many other databases like Sybase
You can, of course, add in the quotes and slash as well.
