Original question:
<I need to combine 2 numbers from 2 different objects with a “/” in between to represent a month/year value.
I can easily do this in BO User Reporting mode using + “/” + . Is there some way to define an object by combining objects with character strings in Designer?>
Many thanks to all who gave me suggestions. The “||” does work for concatening objects (yes, we use Oracle), but the parse regards my “/” as an invalid column name. Is is possible a character other than quotes defines a string in Oracle-based Designer?
-Beverly
