How I can repeat Column Headings on every page without creating
column headings in Headings. I do not want to create column headings in
heading, because it creates alignment problem.
2. How can I automatically bring Query conditions in the report?
It’s right there in the online help: From the Format Breaks dialog, select
the “Repeat the Header on the New Page” option.
Do you mean how can you display what conditions are being applied to the
query? You can display the value a user entered at a prompt by using the
UserResponse function; again, look at the online help for this feature.
