system
February 16, 2007, 9:01pm
#1
Through a custom application I am querying a lot of objects in the CMS repository and I have recently started to receive this error:
CMS operation timed out after 9 minutes.
If I reduce the amount of objects that I am querying it works fine.
I do not want to change my query, so is there a way to increase the time out from CMS?
-J
knowthediff (BOB member since 2005-12-06)
system
February 27, 2007, 8:24pm
#2
FYI, there is a registry hack to change the time out. We chose not to do this and altered our code instead to loop through the id’s but I thought I would post in case anyone elses wanted to know:
Increase the CMS Thread timeout:
In the Windows Registry Editor, browse to the following sub key:
HKEY_LOCAL_MACHINE\SOFTWARE\Business Objects\Suite 11.0\CMS\Instances<machinename>.cms\ThreadTimeoutAfterNMinutes
Double-click the ThreadTimeoutAfterNMinutes String Value.
In the Value data text box, increase the number of minutes until it times out. Click OK.
system
June 12, 2008, 8:55pm
#3
Thanks for this Update. It helps me to run few quearies against CMS.
BOpat (BOB member since 2006-11-09)
system
February 8, 2011, 6:58am
#4
where???
i will find the windows registry editor?
Can anybody help me out for the exact location
Thanks in advance.
saifkhancs35 (BOB member since 2010-04-28)
system
September 28, 2012, 9:13pm
#5
Login to the windows server
Click Start —> Run
Type Regedit
Then navigate the the directory…
jpchase (BOB member since 2011-07-25)
system
September 28, 2012, 9:53pm
#6
I assume something is wrong with your CMS if it needs 9 minutes to proceed a query…
Check KB 1448881 “Multiple instances spawned after daylight savings time change”
Dmytro Bukhantsov (BOB member since 2011-10-14)
