To be secundary server, the BO server must resides with app server, otherwise it is a client node.
If I had 1 primary and 2 secundary clusters. Hence, I have 3 app servers and 3 web servers. Is that right?
If I want to customize applications, sdk, how does it work?
Should I keep all modifications in this 3 environments? (it sounds correct)
ENV: solaris 8 and suone 7
wshiguetaka (BOB member since 2002-08-16)
