Hi folks,
Can I use Freehand sql in webi reports(6.1b).
KSR
bouser_1 (BOB member since 2004-03-20)
Hi folks,
KSR
No.
If you are talking about creating document on Webi with FHS, the answer is no. If you are talking about using BusinessObjects documents based on FHS on Webi, use the search box at the top of the screen, and “search this forum” for “free hand sql” and you will find some other topics discussing that.
