By default to display current month at the Prompt
Hi all
AT the Prompt by default I have to show Current Month at the drop down list and able to select remaining months also.
Please provide soluiton ASAP
Thanks and Regards
bobjkb :india: (BOB member since 2004-03-19)
May I kindly suggest you try a SEARCH on BOB first, suggested keywords: default prompt.
Or look here.
I think you could do it using a customised List Of value using a technic object “creating” months list from a sysdate() or getdate function
like
({fn month(getdate())}) or ({fn month(getdate())}) +1 or … etc
