I am designing a data mart, using ERwin (3.5). Can I export metadata from ERwin into BusObj (4.1.2)?
You should be able to do this via ERwin’s repository. I once tried to read out this info, but was unable because of not knowing all these internal key values of the ERwin repository…
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria Tel: +43-1-8151456-12, Fax: +43-1-8151456-21 e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
As I understand in ERwin, there is an export function to Dbase format. If you export to Dbase, then you can build a SQL statement that would extract the information in an external strategy (I can write more about that) to populate a universe.
Let me know how successful you are.
David S. Morgan
Consulting Services Manager
1120 Avenue of the Americas, 4th Floor
New York, NY 10036
dmorgan@businessobjects.com
Office: 212-626-2626
FAX: 914-735-8027
Purchase Order FAXs: 408-894-1511
from
I’m also interested in the results… let me know. Walter
DI Walter Muellner
