I try to create slices metrics but dimension not appears in PM>metric
- I check definition of metric ==> it seems ok
select : RawData.SalesValueExtra
where : reporting.dimCalendar.WeekDate between @Prompt(‘BEGIN_DATE’,‘D’,mono,free) AND @Prompt(‘END_DATE’,‘D’,mono,free)
==> export universe
update universe in PM
restart AA services and tomcat
check dimension created ==> region dimension : I see all regions
(with option : Yes, I want to create sliced metrics on this dimension) -
I try to create sliced metric ==> no dimension appears (please see attached file)
Could you please help me ?
wellboy (BOB member since 2007-11-15)
