BOXI UserList & Group Extraction
I am not seeing a response that resolves the issue described. I too have both instances installed and manually gone through the refrences to ensure only 11.5 versions are referenced, yet the errors are still suggesting version 12. Has anyone been able to resolve this?
annablj :canada: (BOB member since 2005-04-04)
Hi Julien,
I used version3 excel file for extract users in my environment. Excel file is very usful… i got data in dev and stage environments. when i tried in production i am getting below error.
“crystalenterprise115.infostore.1 --2147213794: CMS operation timed out after 9 minutes.1000440”
Any suggestions…
Thanks in advance for ur help.
Venkat
venkata_somisetty (BOB member since 2009-08-12)
HI
me also facing same timeout error issue. did u get resolve? please let me know the soulution.
thanks,
Venkat
I have tried running the macro and I get the error as follow :
Run Time Error 9 :Subscript out of range and the debugger stops at this line :
Sheets(“Users”).Range(“A3:L65000”).ClearContents
Am using Excel 2003.
Anuputcha (BOB member since 2009-01-07)
Hi Julien,
Thanks for the Excel sheet. I am using XI R3. When I run the macro on R3 environment, I encounter a error on the Macro.
I checked with my friend who has XI R2. He was able to retrieve the list.
Please help me on resolving the error in the macro & retrieving the user list from R3.
Ash
nvlashok (BOB member since 2005-10-20)
Is there any macro for extracting user list using Windows AD ?
Asmitha
Asmitha :uk: (BOB member since 2008-06-06)
Not working for me tooo :cry:
When i enter CMS detail and click on “Extract data from CMS”, gives error,
“VBAProject - 458: Variable uses an Automation type not supported in Visual Basics 1000458.”
I am using BO XI 3.1 and MS Excel 2007.
Thanks in advance …
Vills :india: (BOB member since 2007-10-24)
Julian,
I have fixed the macro to work in 3.x. Should I send the macro back to you to upload the new version here ?
kapilmalik :canada: (BOB member since 2006-03-23)
Hi julienbras,
Thanks for your Excel sheet…I have one issue.
2months back i downloaded your Excel sheet it worked fine but last week I installed Live Office and today I am trying to run the excel sheet and it is throwing one error as:
“VBAProject-5 Invalid Procedure Call or Aruguemnt 1000005”
Please, help me …
Thanks [/b]
Nalin :india: (BOB member since 2008-07-18)
How make these script works under LDAP login?
lunar3000 (BOB member since 2008-04-15)
This utility is working great. I can able to pull all the users (~10K) from repository, however when I apply filter on group in the excelspread sheet it is not giving me all the users in that group. Am I doing something wrong?
-Nivas
Nivas74 (BOB member since 2009-12-07)
Hi all,
with the download from this post I am able to extract and modify user list… is there any way to insert new users… we have a enterprise authenticated env and now there’s a req to add all users from a DL…
Rekha
rcr (BOB member since 2009-04-13)
Hi OllyB,
Could you please send across the BO DeskI report which you created using the VBA code. It would be a BIG help for me.
Waiting for your reply.
Prabhat Jha
itisprabhat (BOB member since 2007-07-04)
Have you received an answer to your question?
tim schulte :us: (BOB member since 2003-12-11)
Did you try simply using the import wizard …
This is a great utility, however is it possible to extract the users and groups by using a batch (non-interactively) ?
thx in advance
vivek
vivekgandhi (BOB member since 2010-03-02)
You can use csvde to extract AD user list.
regards
Vivek
Hello,
I keep getting this error.
VBA Project - 458:Variable uses an automation type not supported in Visual Basic 1000458
I noticed more people had it but cannot find a solution.
Does anyone know why I get this error? I’m using Office 2007
thanks a lot
N
Tiger37 :uk: (BOB member since 2010-04-07)
Hi all,
First of all THANK YOU VERY MUCH! :wink: Great Job! :+1:
I think all these information should be in the first post, no? :yesnod:
It would be very appreciated if this link could be too in the first post. Is there a moderator in da place? :bob:
No news? :?
Gôm
I really like this file, it is very useful, and works great.
The only problem I had is that it uses Enterprise login instead of Windows AD (which my company uses).
So I modified it to use Windows AD, I wanted to see if anyone else is interested in that, if so I can post it up here.
Bolandb (BOB member since 2010-06-08)
