Kindly assist me in resolving issue on SSI.
Below is the error i’m getting.
There is an error when getting a serialized session: com.crystaldecisions.sdk.exception.SDKServerException: Enterprise authentication could not log you on. Please make sure your logon information is correct. (FWB 00008)
cause:com.crystaldecisions.enterprise.ocaframework.idl.OCA.oca_abuse: IDL:img.seagatesoftware.com/OCA/oca_abuse:3.2
detail:Enterprise authentication could not log you on. Please make sure your logon information is correct. (FWB 00008)
The server supplied the following details: OCA_Abuse exception 10496 at [exceptionmapper.cpp : 67] 42040 {}
…Enterprise authentication could not log you on. Please make sure your logon information is correct. (FWB 00008)
Thanks and Regards
alancutaran (BOB member since 2011-11-18)
