BO Personal Trainer Installation problem
I tried to install BO Personal Trainer 4.1 on a Windows 95 PC. I ran setup.exe and got an Isset_se error message, the details of which are listed below:
The program has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor. ISSET_SE caused a general protection fault in module setup.exe at 00001:000032cc. Registers … (lots of registers listed here).
Has anyone encountered this error, and is there something I could do to fix it?
Kamini
(kshenoi@citgo.com)
Kamini,
we also had sometimes strange problems/errors after the installation of the Trainer.
We solved them by installing the ODBC Verison that is on the BO-Trainer CD. Just give it a try, I hope it helps.
Mathias
below:
The program has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor. ISSET_SE caused a general protection fault in module setup.exe at 00001:000032cc. Registers … (lots of registers listed here). Has anyone encountered this error, and is there something I could do to fix
it?
Kamini
(kshenoi@citgo.com)
