BO : Crosstab with several classification
X-cc: Jean-Marc MOREL jmmorel@Camaieu-Homme.com
I use BO 4.1.2 on Oracle Database (Ver 7.1.6).
Here are the information i have in database :
Shop ind 1 ind2
nƒ1 15 20
nƒ2 17 12
nƒ3 16 15
nƒ4 20 13
And i want to obtain this crosstab :
shop ind1 order 1 ind2 order2
nƒ4 20 1 13 3
nƒ2 17 2 12 4
nƒ3 16 3 15 2
nƒ1 15 4 20 1
Does someone have an Idea to realize this document.
Thanks a lot
Laurent DUMONT
Chef de Projet Informatique
TÈl direct : 03 20 99 37 49
Fax : 03 20 99 95 10
You can do this:
Create a new variable called <ind1 - negative> with the formula “= -1 * ”. Do the same for ind2.
Then use the ranking function with the formula: Rank( ,<ind1 - negative>) for each of your classification columns. Then set a descending sort on each of these columns starting form left to right.
Best Regards,
Andrew J. Erthal
Post Sales Consultant - Central
Business Objects Americas
aerthal@businessobjects.com
Chicago Office (847) 391-9898
St. Louis Office (314) 209-1994
St. Louis Fax (314) 209-7926
From: Laurent DUMONT [SMTP:ldumont@CAMAIEU-HOMME.COM] Hi,
Shop ind 1 ind2
nƒ1 15 20
nƒ2 17 12
nƒ3 16 15
nƒ4 20 13
nƒ4 20 1 13 3
nƒ2 17 2 12 4
nƒ3 16 3 15 2
nƒ1 15 4 20 1
