Hello everyone
Whenever I drag a dimension from Report manager to the actual report, the dimension data values who up allright- but the header information is missing i.e. I have to physically label the column headers.
Is this a bug with BO version 6.0 ?
~Rohit
HI Steve
I am haivng the same problem after migrating to 61b also.
I have tried dragging it twice- it either createds the same column twice or overwrites the neighboring column.
~Rohit
Steve,
An update on the previous post -
I have a cross tab in BO. While testing it ā¦users drag out certain columns and drag them back in .
When they do drag them back in; we have the issue of blank headers.Also āShow Variable headerā & āBo version 3.x corsstabā options are enabled.
Chances are that a āCustomā Header was created at one time. Custom headers do not follow the data around, so that could be your issue. Iād remove the headers (unchecking the box) and then adding it back again.
Your headers should read along the lines of: =NameOf()
If it does not, then that was definitely the issue.
