BO and XML
Does anybody has any information, wether BO is going to support XML in next version. I mean bot to read XML files and publish XML files…
Ronen Baran, System Analyst
Tecnomatix LTD.
Mail to : rbaran@tecnomatix.com
Telephone : 09-9594856
Ronen,
Yes, look for B.O to support XML in its next major point release. There was some talk of this at this year’s user conference. I even thought I heard they were working on a Q1 2000 release date, although that seems rather early. Either way, be assured that B.O. will embrace the XML standard in the future. Talk to your sales rep., who should be able to provide you with more information.
Neal Messier
Fidelity Systems
Neal,
Do you know if they plan to support publishing xml, or also reading xml files?
Hi All:
I need information of support to Business Objects with XML. Where I can find more information? Dou you give me a example? or where i can find a example?
XML or XML Api¥s
BO 5.x
Thanks and regards.
Luis Sanchez M.
Webi Data, SA de CV
Monterrey, N.L., Mex.
XML or XML Api?s
BO 5.x
Does anyone (particularly the consultants out there) have any info on BO support for XML?
Devon
Devon,
BO has no native support for XML. However the new jsp tag library (JASPER) which is finishing Beta now will support XML/XSLT when developing with the JavaBean SDK for webi. Feel free to contact me directly for some other ideas about how to integrate BO and XML.
Cheers,
Ben
There is an xml addin ( vb Macro ) which alows all reports to use Xml as the source and export the results to xml.
This works well.
Its not too difficult to write your own if required, using the Microsoft Dom.
I think this is available from the partner website.
Cheers
Mark Taft - Misys Group
Hi Ben,
My name is kiruba. my requirement is, i have to create universe using XML as data source. i found that, this is possible in BO XI R2 version. but other than this new version, i dont know how to use ‘xml as data source’.
could you please send me these details???
[i dont know whether you are seeing this BOB currently. because you posted this in 2001.]
here i placed my mail id: kirubasankarrv@hcl.in
i’m expecting your answer
thank you,
kiruba
anbe_sivam :india: (BOB member since 2005-09-21)
