Bitwise AND on two variables
Hello all,
We’re using BO 5 and WEBI 2.5 on an Oracle 7.3 database. I want to perform a bitwise AND on a number retrieved from the database. For example: status is retrieved from the database and contains the value 9 (1001b). I want to see whether bit 4 is set. The only solution is to perform a bitwise AND on status: if status AND 8 = true then bit 4 is set. I want to give a variable a value, depending on whether bit 4 is set. We use this type of operators quite often here. Does anybody know how I can solve this? Something like decode(status AND 8,true,‘Ready’,‘NOT Ready’) should work, but the AND operator is not available.
Thanks, Tim Lauret
Tecnomatix Machining Automation
Enschede, the Netherlands
Use decode(mod(trunc(status/8), 2), 1, ‘Ready’, ‘NOT Ready’).
A Generic formula to get a particular bit value of status field would be:
mod(trunc(status/power(2, )), 2)
where is the bit position starting from right to left with 0.
-Venkat
Hello all,
Thanks, Tim Lauret
