i keep getting this error message when i submit a document to be refreshed.:
(109)Connection or SQL sentence error:(DA0005):[[Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user’jbloggs’.18456]The following data providers have not been successfully refreshed:Query one with Wldtg. (DMA0007):[]
Document is from full client 6.1a
Broadcast agent 6.1a running om windows server 2000
Database is sql server2000
anyone out there know what it might be?
i checked the odbc on the server and it looks ok, i also ran this report manually on the business objects server and it refreshed ok.
That sure sounds like an ODBC connection problem.
Triple check the connection (yea, i know you already double checked it)
There’s a TEST CONNECTION dialogue at the end of the SQL Server ODBC Config, Successful?
One other thought, is the connection correct on your actual BCA server? If you’re running multiple servers, I would make sure it’s configured correctly on every cluster and node in your environment, especially the BCA server.
thx Chris, good to finally find a decent bus objects forum,i was getting a bit fustrated with bus. objects own site.
sadly no joy with this though, i go through the odbc connection and do the test and get the test successful! message but still get the same error when i try to do the scheduled refresh.
this is the connection on the server bca is running on.
the jbloggs login is the business objects login of the user who created the report, which is also a login for the sql server database.
a different sql server login(with sysadmin rights) is used for the odbc connection on the bca server.
to both your questions yes,these are the same settings i have on the bca server.
on the test connection screen:
Microsoft SQL Server ODBC Driver Version 03.70.1146
Data Source Name: BO6_Repo
Data Source Description: BO6_Repo
Server: XXX123
Database: BO6_Repo
Language: (Default)
Translate Character Data: Yes
Log Long Running Queries: No
Log Driver Statistics: No
Use Integrated Security: No
Use Regional Settings: No
Prepared Statements Option: Drop temporary procedures on disconnect
Use Failover Server: No
Use ANSI Quoted Identifiers: Yes
Use ANSI Null, Paddings and Warnings: Yes
Everything looks the same except for the driver (we’re using 03.81.9042)
So there’s probably a later driver you can try, but i doubt that’s the problem here.
Your connection is called BO6_Repo … Is your repository on SQL Server?
Are you looking at the SystemDSN for your data source or for your repository?
Maybe double check the universe connection and see where exactly it’s pointed.
oops yes, i’m probably confusing the issue.
both the repository & data are on sql server - different databases though.
the dsn for the data gives:
Data Source Name: RP_User
Data Source Description: RP_User
Server: XXX123
Database: (Default)
Language: (Default)
same error as i first posted.
i am even able to manually run the report from business objects on the bca server itself.
i checked the systen dsn the universe is using & it’s the same as on the bca server.
it’s weird becuase we have a seperate bca server/repository/database in the US but it’s basically set up in exactly the same way as this euro one & scheduled reports refresh on it ok.
