Basing a Query Filter on a calculation / variable
Hi folk,
I have no doubt this has been asked before, but I cannot see anything similar.
I need to create a query filter that is something like:
where Fiscal year between (select fiscal year - 2) and (select fiscal year).
Select Fiscal Year needs to be a prompt and then select fiscal year - 2 is just a calculation of the prompt value - 2.
Can this be done, or do I need to present the user with 2 prompts instead?
debbi.frost (BOB member since 2015-12-08)
Do you have access to the universe to create a pre-defined prompt ? Or do you need this @report without any universe changes ?
Shobhit_Acharya (BOB member since 2005-08-11)
If I could do it without universe changes that would be good. Is this possible?
These types of parameters are best added on to the universe. In a pinch if you have to do this at a report level, I don’t see any other option except a custom sql. You’ll have to edit and customize the where clause in the custom sql.
where Fiscal_year between @Prompt('Fiscal Year','A','Class\Fiscal_Year',mono,constrained) -2 and @Prompt('Fiscal Year','A','Class\Fiscal_Year',mono,constrained)
I’d add a second data provider DP2 which is “custom” instead of the original DP, and source the results of DP2 in the first but that is not absolutely necessary though.
Only at the Universe level possible. No edit at Query prompt to get dynamic dates possible. Go to Uni. level @prompt option(best practice) or Custom SQL(maintenance overhead and migration issues) !
kch :us: (BOB member since 2005-04-08)
Thanks folk.
To be honest, I could never see the simple creation of a prompt vs. custom SQL, for custom SQL to be an option.
Create the prompt :wink:
Thanks Mac. I would do if I had access to the universe. It is one that is due to be deprecated, and we have a dev freeze on it. I am specifying that in the new one that we have proper parameter prompts. Thanks for the advise.
I’ve just seen so many problems later on.
Custom SQL is not a good option, IMO.
