Autofit-Function?
is there a flag to set the size of a cell to automatically fit its contents? If you have “ABCDEFG” as the content the cell should have the correct size to display all letters
Hannes
Place the cursor at the right edge of the cell until you see the parallel lines. Double-click and the cell is resized. I’m not sure if it is resized to fit the biggest value for the field in your query -----Original Message-----
Date: Thursday, August 13, 1998 8:21 AM
contents?
Hannes
BUSOB-L-Request@listserv.aol.com
For old 3.1 info: Penn: Page not found
Search: Mail to listserv@listserv.aol.com, ‘search a_phrase in
BUSOB-L’
(Sorry - I sent the original message before it was ready)
Place the cursor at the right edge of the cell until you see the parallel lines. Double-click and the cell is resized. I’m not sure if it is resized to fit the longest value for the field in your query or the longest value for
that field in the database.
George Baranowski
QuadraMed
