Authorization for documents
I inherited a document from my ancestor, it allows any users to open and submit to DA.
However, once it is being retrieved from the repository, only the administrator can open the document
and the extension changed from .rep to .cpr. When other users tried to open the document,
they will get “You are not Authorized to Open this Document” error message. I tried Robert’s suggestion but it didn’t work for me. Does anyone have any idea?
Robertdigpen@EARTHLINK.NET’s suggestion:
Open this document with a General Supervisor and then do a ‘Save for
all
Users’ (in 4.0.5.5. it was save in Workgroup Mode). You should then
be
able to open this document under any id. Once you can, reexport it
and all
should be well.
Thank You
Angie
