All,
I am trying to apply a sum calculation on a colum that contains numbers
without choosing the identifier column. For this I need the duplicate rows,
since any number can appear several times.
In the data provider option there is a radio button for allow duplicates,
however it doesn’t help. Any suggestions ?
Ronen Baran
MIS, Tecnomatix
Tel: 972-9-9594856 Fax: 972-9-9544402
Select your table, then go to Format|Table… and check the ‘Avoid
duplicate rows aggregation’ in the General tab. That should do the trick.
HTH,
mirko
All,
rows,
