is it possible to add a bitmap to a report with a script?
I have a report which runs for about 50-times and I want to add every
report an other picture. I want not to send it 50-times to DAS.
Alexander
Mit freundlichen Gruessen
DSB, Daten-Service Beck GmbH
Alexander Zipf
Add a table in the database that associates an image file name with each
data value (e.g. data value 1 associated with c:\windows\circles.bmp)
Add a cell in the report, and insert the file name field into it.
Go to formatting, number, choose image, bitmap to display the image in
the cell, rather than the path name.
Note that sizing the cell just right for the image can be a little tricky,
since by default, it resizes the image to the cell, rather than the
opposite…
Alexander
Alexander Zipf
