ActiveX Error
When we trying to vew BO report from AF dashboard (in EDF), there is an error appears:
“ActiveX Error page TODO”
And curiously that 2 report are viewed normally and third report cause an error.
What are we must do to fix this error?
relgames (BOB member since 2004-04-26)
does this happen in webi too?
check the log.
wshiguetaka (BOB member since 2002-08-16)
I have this problem too. Now that the users want to see all documents with activex. One thing that I noticed: DO you have how many entries for Business Objects in DCOMCNFG?
Got the solution:
the report is not updated, the universe has been changed but the report wasnt updated. If you import the report you will get an error. Get a local version in your machine and overwrite the old one. It will work after that.
Let me know your findings
