I’d love to hear from those of you, that had to do something to work around the 5000 rows limitation
in BO. Any solutions, ideas?
I have got a report that will return more than 5000 different rows in a short time. And it will grow…
I have no idea how to deal with it, so far…
around the 5000 rows limitation in BO.
You can change the default limit for the universe under File / Parameters / Controls tab using the Designer.
Another method, which is very handy, is to copy the SQL code generated by the query and run it using Free-Hand SQL.
Lorenzo Escalante, Jr.
BHP IT Perth, Western Australia
escalante.lorenzo.lj@bhp.com.au
Open the Univers in Designer. Select Parameters from the file menu. On the Controls Tab change the max number of rows.
Umm… Hmm…
First of all: Thanks, that works!
But then, what is the meaning of ‘Maximum Number of Rows Fetched’ option in Database tab
of Tools->Options in Designer, which has a fixed limi of 10k (in 4.1.2a, which I use now,
in version 4.1.1 that I have been using two weeks ago it was 5k - hence the subject ).
option in
Database tab
4.1.2a,
which I use now
That’s the maximum number of rows fetched when you want to see what records are present in a table or what values a column has (right mouse click, values) on the table or on a column in the structure window in designer (I use the default of 100 rows, that’s usually indication enough).
